Small block valve lash
Old Sep 24, 2017 | 2:56 PM
James Nash's Avatar
Default Small block valve lash
Hi guys new to the forum i know there's probly afew threads on this but I couldn't find anything to help my situation,
i have a 350 sbc i got the engine its got a unknown cam and afew other goodies i want to set valve lash but i dont know if ive got solid or hydrolic lifters whats the best way to check or set valve lash without knowing this
Old Sep 24, 2017 | 3:15 PM
kevinkpk's Avatar
Telescoping magnet, pull a push rod out, drop the magnet in the hole, remove lifter. Go from there. Valve lash is always the same, BUT with hydraulic lifters you really need them expanded. I used to have a sbc valve cover cut open, and would adjust back lash with the engine running
Old Sep 24, 2017 | 3:30 PM
James Nash's Avatar
Yea ive ajusted it running before but thought id ask the question, adjusting it running ya just loosen it off til it ticks then do the nut up till the ticking stops plus quarter of a turn that correct?
might have to get the get and old rocker to cover to cut open 👌
Old Sep 24, 2017 | 8:10 PM
kevinkpk's Avatar
I'd suggest since you are doing it the "old fashion way", tighten them till they stop ticking, leave it at that.
Old Sep 24, 2017 | 8:11 PM
kevinkpk's Avatar
Should add, just till they stop ticking
