Smoking on initial start-up
Old Apr 1, 2010 | 5:49 PM
fastera's Avatar
Default Smoking on initial start-up
My 2004 Tahoe is smoking on initial start-up. It seems to oil smoke, but it is not constant like a broken ring. After about a minute, the smoking clears up. Coule it be the following:
  • A broken ring
  • A sticking injector causes excessive fuel after shutdown
  • A blown head gasket causing oil to seep into the chamber during shutdown
  • A broken valve stem seal
What should I check first???
Any ideas?
Thanks
Old Apr 3, 2010 | 3:28 PM
DHT112A's Avatar
Most likely worn stem seals. Oil leaks past them when engine is not running and burns off when started.
Old Apr 3, 2010 | 8:00 PM
MDTAHOE's Avatar
Professional Mechanic
X2 on valve seals
Old Apr 3, 2010 | 9:41 PM
Terry Neff's Avatar
Might help if you said how miles are on it.........
rtobias1972
Sep 27, 2014 12:01 PM
fredster
Aug 15, 2014 1:41 PM
Buckeyegrad02
Aug 17, 2011 9:04 AM
2wd-K5
Aug 29, 2010 12:55 AM
Thermool
Jun 20, 2009 6:41 PM
