So, my 98 Tahoe doesn't shift past neutral.
Old Sep 22, 2016 | 10:17 AM
TFC4104's Avatar
Default So, my 98 Tahoe doesn't shift past neutral.
I've given it liquid. I've adjusted the transmission cable to arm, it functions properly. Even from the bottom it will put the truck in drive, but the truck just won't go. In stumped. At first the cable are was falling off because the grommet came off. Fixed that. I did the cable adjustment and now it at least shows when it's in drive, reverse, or neutral, but I should note, the only neutral works. Reverse isn't when the gauge says its in reverse. Sometimes it shifts into drive. It won't show it on the gauge, but the truck will move.
I'm ****ing at a loss. I'm figuring things out as I go as this is my first vehicle. Any help? Please. Desperate college student who needs this thing to run!
Also, even when manually shifting the arm that the cable connects to out of transmission, the truck will basically stay in neutral. I've gotten most of my info from you guys. So hopefully you can help! Before I did cable adjustment the light wouldn't even come on when changing gears.
Old Sep 22, 2016 | 12:19 PM
kevinkpk's Avatar
I hate to say it, but it's probably an issue with the parking mechanism. I had basically the same thing on my 96 lumina.
Old Sep 22, 2016 | 1:53 PM
TFC4104's Avatar
So how did you fix it? Was it costly? I got it into drive this morning although the gauge didn't reflect that it was in drive. It won't show past neutral. But I was able to get it into the driveway from the street.
Old Sep 22, 2016 | 3:07 PM
kevinkpk's Avatar
Took it to a transmission shop, overhauled it (at 185K). You (with help) can rule out the cable. Put it in neutral, unhook the cable, start it up, and have someone shift it in drive. Not recommending it, but that's what I would do.
Old Sep 22, 2016 | 3:36 PM
TFC4104's Avatar
I've done this and it does seem to work. Sometimes. The arm is a little loose I've tightened it but it's hit or miss. This was before transmission fluid.
Old Sep 22, 2016 | 4:05 PM
kevinkpk's Avatar
Replace the shifter arm, see if that works. I still have a minor issue with my shift cable.
Old Sep 26, 2016 | 12:19 PM
Spencer Kitchen's Avatar
might be the the little pin that actually shifts the gears, you might of put it in park and let off the break to fast and the weight might of bent the pin, easy to replace if you dont minf getting a bit dirty
