Squeaky Springs
Old May 15, 2008 | 8:07 AM
Splais's Avatar
Default Squeaky Springs
I have a 2003 S-10 KR5 Crewcab. My problem is I have a squeak someplace in the rear springs I can't get rid of. Every time I push up and down on the back end I get this terrible squeaking sound. I've tried to pinpoint it and best I can tell it comes from the leaf springs. I have washed them off, sprayed WD40 between leaves and nothing has worked. Can anyone provide any suggestions hear to help me out
Old May 15, 2008 | 3:45 PM
shawnvw's Avatar
Banned
Default RE: Saueaky Springs
Try using the WD on the rubber bushings. One may be dry. Also want to look to see if the bushings are so worn, that there is steel rubbing against steel near the Bolts
Old May 15, 2008 | 8:07 PM
old dog's Avatar
could be one or two things ,the nylon wear pads on the ends of the leaf'e are worn out ,or the eye bolt's that hold the spring's to the hanger's are too snug .it help's too remove them one at a time and put never seize on them .had to do it to several new trucks.
Hatchfinder
Jun 4, 2008 4:59 PM
txguykev
Dec 2, 2007 5:26 PM
Chunkymonkey
Aug 10, 2007 6:58 PM
hatchet
Jan 3, 2007 11:30 PM
doo600
Dec 12, 2006 12:38 AM
