Anybody else with squeaky rear brakes?
Old Dec 11, 2006 | 12:33 AM
doo600's Avatar
Default Anybody else with squeaky rear brakes?
Only got about 2,000 miles on mine but if I start to drive and use light pedal pressure it squeaks real loud in the rear brakes. I'm sure it's the metallic pads and probably rust on the rotors. just wondering if anyone else had this. I'm sure a change to ceramic pads would probably cure this.
Old Dec 11, 2006 | 9:33 AM
schorner's Avatar
Default RE: Anybody else with squeaky rear brakes?
I get a little squeek pulling out of the driveway first thing in the morning. It clears up by the time I get to the end of the street, but it is loud enough to notice.
Old Dec 11, 2006 | 2:27 PM
ZX1100F1's Avatar
The noise is probably a result of contamination, spray the caliper and pads out with high pressure water thoroughly and then apply the brakes aggressively several times in rapid succession from at least 45 MPH down to 0.
I'd caution against installing ceramic pads on the Tahoe, they are quite but do not offer the same stopping power as the OEM semi-metallic pads for this heavy vehicle.
Old Dec 12, 2006 | 12:38 AM
doo600's Avatar
ORIGINAL: ZX1100F1
Thanks ZX, I'll try it. It does clear up pretty quick into the trip so it doesn't concern me.
wolfdogg
Feb 18, 2012 1:58 AM
matryd
Uplander
Jun 25, 2011 12:25 AM
Mille Racer 69
Dec 8, 2010 8:26 PM
Hatchfinder
Jun 4, 2008 4:59 PM
07LS
Mar 28, 2007 4:35 AM
