stall problem on 02 4.8l
Old Feb 4, 2008 | 8:46 PM
haulinloads's Avatar
Default stall problem on 02 4.8l
I have an 02 silverado with a 4.8 and was planning a recent trip to florida (for daytona). I did all the bascic tune up things...ie..plugs, wires, filters. While doing the wires i broke the coolant temperature sensor on the side of the block on accident. So, i thought no biggie order a new one. Well i put it on, and topped off the coolant. It ran fine the day, but here is where the troubles start. The second day of driving, the coolant gauge will go all the way up, then drop to the lowest point and the truck will cut off. The first couple times the truck started right back up, but now it takes a couple times to start up. the car will also hesitate like no other, and act like it wants to stall out, while trying to accelerate. I know i have a bad coil, beacuse i snapped the end on accident(the same day...doh) and rtv'd temporarily. i feel a slight, very slight miss. but i think all the problems are from the CTS. How do i go about bleeding the system? I was told that could be it.
Please help a fellow chevy man
i also posted this in the silverado section
Old Feb 5, 2008 | 3:09 PM
shawnvw's Avatar
Banned
Default RE: stall problem on 02 4.8l
While the CTS could be the problem, I would be more concerned with the coil you broke. you are probably getting an intermittent connection causing the hesitation and stalling.
As far as bleeding the air out of the system, take the rad cap off(when its cold) warm up the engine untill the thermostat opens up, the top rad hose will get hot when this happens, then add fluid to the rad.
If your truck has gone from fully warm to full cold, then the antifreeze that was in the reservoir should have been sucked back into the rad when the truck cooled down and should be full already. You just need to add some more the the bottle
Stocked88
Aug 31, 2015 4:04 PM
scott291racing
Jul 9, 2010 4:09 PM
dsettlemoir
Jan 25, 2009 7:44 PM
haulinloads
Feb 4, 2008 8:41 PM
mikeryan
Oct 8, 2007 8:26 AM
