Stalling issue
Old Dec 26, 2015 | 9:59 AM
Lui p's Avatar
Default Stalling issue
I dont know if yall can help me with my issue or if tbis is the right place to ask but i am having problems with my 97 chevy tahoe 5.7 4 door 4x4.
The problem i am having is i have replaced fuel regulator and fuel pump and fuel filter and it is stalling out and hard to start now and never had the problem before and is not throwing any codes.
Fuel pressure key on is at 50 psi and around 55 psi when running when it decides to finally start.
Any ideas any more questions ask and i can answer it about the truck im hoping its not the spider injection system or the computer. Any help will be appreciated
Old Jan 1, 2016 | 11:16 AM
slowspeed's Avatar
sounds like same issue i had with my 95 blazer have you checked the coil and under the distributor rotor there is a electronic device looks almost horse shoe ish don,t know the name of it but that can go bad do not replace with cheap parts found out they will go bad fast if parts are bad get a Napa premo part and it will last a long time.
hope this gets you in right direction.
Old Jan 2, 2016 | 11:41 AM
Lui p's Avatar
You are speaking of the second crank sensor called the hall sensor and yes it is changed out and it is an ac delco
