Starting Issue 1990 K1500
Old Feb 17, 2014 | 9:21 PM
JayDm's Avatar
Default Starting Issue 1990 K1500
I have a 1990 k1500 Single cab 5.7L V8 350. I replaced the ignition coil on it because after running some tests I figured that is what was going out just to be sure I took it in to get it and the ignition control module tested and the coil was bad. So I installed the new one and I still have the same problem. I tested the starter and I tested the battery everything seems to be working fine But my truck still won't start. It turns over but it won't fire. Please If someone can help me I would really appreciate it.
Old Feb 18, 2014 | 8:35 AM
Are you sure it is an electrical problem? it might be fuel related. Spray some starter fluid into the throttle body and see if it tries to start and kicks over some. If it does then it is fuel related. You might also do a fuel pressure check.
Old Feb 18, 2014 | 3:14 PM
JayDm's Avatar
I tried putting starter fluid in the throttle body and it is still having the same problem. I tested the spark plug wires for spark after I replaced the ignition coil and they still aren't getting spark.
Old Feb 20, 2014 | 7:44 PM
JayDm's Avatar
please guys this is my daily driver and i'm at my wits end. Any help would be greatly appreciated.
Old Feb 20, 2014 | 8:43 PM
habu's Avatar
Default Same thing happened to me .... just wouldn't start
I knew I had a new cap, rotor, wires, plugs but could not get it to fire. I called for a tow truck and the guy took it to a shop that he recommended. It was the distributor. The head mechanic had seen it happen before and of all the times that he tried to mend different distributors, he said it's best to just replace them.
Old Feb 20, 2014 | 9:24 PM
JayDm's Avatar
That's what I keep coming back to. I just want to test everything before I buy a new distributor because the one that's in it isn't old at all.
KLamp91
Feb 7, 2014 10:41 AM
opie4487
14
Jan 18, 2014 12:10 PM
growlerv
Nov 22, 2012 4:26 PM
Salvatore
Jun 14, 2011 6:15 PM
opie4487
Mar 14, 2007 11:19 PM
