Starts, runs then will not start again.
Old Jul 8, 2008 | 1:53 PM
mtodd001's Avatar
Default Starts, runs then will not start again.
Hey CF, I'm new here. OK, here goes I have a 1989 Cheyenne 2wd shortbox w/ 350(orig 6cyl). It cranks from a cold start with no problem and runs great, but if I shut it off to run in the store it will not start when I try to start it. It cranks, sounds like it will turn over then that's it...nothing. If I let it sit for an hour or so it will fire right up and run fine again.
Any help is appreciated.
Mike
Old Aug 15, 2008 | 6:16 PM
elorocks17's Avatar
Default RE: Starts, runs then will not start again.
It might be hydrolock. I have a similar problem with my 1994 Van. When I turn the key, it just makes a "chunk" sound. Sometimes it can be jumpstartedsometimes it cannot. I would ask someone about it before its too late like my van is.
Old Aug 17, 2008 | 11:38 AM
therewolf's Avatar
The obvious answer is the choke. The other thing you may want to look at on a high mileage engine is the valves-run a compression test.
casedonovan
Sep 17, 2015 8:42 AM
jdom19671
Jun 25, 2012 10:10 AM
snowonweb
Oct 25, 2008 3:42 PM
brenande
Jan 27, 2008 12:40 AM
Ladydriver
Jan 4, 2007 7:33 PM
