still battling...
Old Jan 18, 2010 | 11:58 AM
maxxman04's Avatar
Default still battling...
'98 tahoe, 350 vin R
NEW: cap/rotor, brass contacts/autolite platinum plugs/splitfire wires/fuel pump/fuel filter/air filter/bank 1 sensor 2 o2 sensor.
old plugs ok, except #5, covered in soot. #3 very slight soot. code p1345, had cam offset checked/set. now back to p0305. engine runs great, no power loss, but slight miss at idle. i've reset code multiple times with scan tool. fuel pressure is normal. was told to check EGR valve. wouldn't this set a different code, or misfire code on other cylinders as well? from what i've read, i may have faulty injector or poppet on #5.
like most, i cannot afford to go to dealer, but also cannot afford to just throw parts at this thing with fingers crossed. rig runs and drives great, no issues other than the slight miss at idle. any thoughts? ideas? things to check? something i'm missing?
Old Jan 18, 2010 | 1:46 PM
maxxman04's Avatar
UPDATE:
with an older actron SCANTOOL, generic OBDII cartridge, this is the info (live data) i get:
ABSSLT TPS % 0
Calc. Load % 3.1
RPM 640-675
Fuel Systems 1 and 2 closed
IAT 59 deg
Ignition Adv between 22-25
LT FL TRM 1 2.3%
LT FL TRM 2 -10.2%
MAF .92-.95 lb/m
MAP 9.7 "/hg @ idle--8.6 @1500 and higher rpm
o2 bnk 1 #1 % 10-75
volt- 0.1-0.6
o2 bnk 1 # 2 % 66-70
volt- 0.8-0.9
o2 bnk 2 #1 % 10-70
volt- 0.1-0.9
o2 bnk 2 #2 % 11-15
volt-0.15
ST FL TRM 1%- 0.0 - +1.6
ST FL TRM 2%- -0.8 - +0.8
codes P0000
P0305
svilla81
Sep 19, 2007 10:36 AM
TBarwick1
Jun 5, 2007 9:26 AM
wllb777
Dec 29, 2006 5:47 PM
Iowajeepin
Apr 27, 2005 10:20 PM
