Notices
Tapping SBC for Accessory Bracket
Old August 7th, 2021, 9:36 PM
Pilotpat's Avatar
Default Tapping SBC for Accessory Bracket
Hello. I built a '73 5.7 block up into a running motor for my first build. I've picked up an OBS truck with a 4.3. I want to use the accessory brackets from the 4.3 but the Alt/PS bracket has a bolt and stud that mount to the block at the bottom. The upper bolts have taps in the heads but my block does not have tapped holes for the lower two but does have what appear to be "Bosses or Pad's" where they would go. Q: Is it appropriate to drill and tap those locations for the bracket mounts. Thanks for any replys.
Patrick.
97chevyproject
December 3rd, 2014 7:21 PM
fmsons@bektel.com
January 6th, 2013 9:22 PM
89Sierra409
April 24th, 2012 9:36 PM
someridefree
November 13th, 2011 6:20 AM
Quick Reply: Tapping SBC for Accessory Bracket
