Timing Belt? Help!
Old Jan 8, 2012 | 2:38 PM
dgbrooks's Avatar
Default Timing Belt? Help!
Have a 2000 Chevy Suburban 1500 4wd with 155,000 miles. Getting sounds from engine as accelerate in lower gears. Sounds almost like belt squeek, but also has almost a low grinding or vibrating sound. Not sure if this is the beginning of timing belt issues, or something in the alternator. Any suggestions on what to check? Thanks!
Old Jan 8, 2012 | 5:31 PM
EinST's Avatar
I assume you mean serpentine belt since there's no "timing belt." Do you hear the same noise when you rev it in park? If so, find a way to listen for the source of the noise with something like a mechanic's stethoscope or even piece of a flexible hose. If not, I'm not sure what to recommend but I myself occasionally use a Chassis Ear tool.
landon101
22
Nov 14, 2021 10:48 AM
jmms
HHR
Apr 17, 2015 4:22 AM
AshleyFeucht
Sonic (Aveo)
Jul 19, 2010 8:03 PM
SOS
Jun 19, 2009 2:59 PM
LetsGoMets78
Cobalt
Dec 18, 2006 2:48 PM
