tint removel/ looking for removal tricks
Old Jan 29, 2009 | 5:09 AM
adamant's Avatar
Default tint removel/ looking for removal tricks
removal is not bad .its the glue.. what can i do?
Old Jan 29, 2009 | 6:00 PM
shawnvw's Avatar
Banned
buy a heat gun. do it in a garage to make sure the windows are warm, and use a heat gun while peeling it back. Should get most of the glue with the film, then use a razor blad for the stubborn parts...but not where a defogger grid is present. You might use brake and parts cleaner or acrysol with a rag also
Old Jan 29, 2009 | 8:41 PM
MDTAHOE's Avatar
Professional Mechanic
Any glass cleaner with amonia in it works great. The more anomia the better. You could use amonia and water mix but the odor would be terrible. Auto parts stores may sell something specificly for that
Old Jan 30, 2009 | 7:35 AM
EvansBlue's Avatar
Never had any good results with high amounts of ammonia. Tried it once and it just turned it purple.
A heat gun is the best way to go. Heat the window evenly, then concentrate on your starting point. As you peel, spray the part you peel up with windex or alcohol so that it doesn't flop back down and stick again.
Old Jan 30, 2009 | 9:11 PM
MDTAHOE's Avatar
You have to remove the film then clean glue off with amonia
marck83
Dec 10, 2013 5:03 PM
rcott
Dec 22, 2012 8:07 PM
cva617680
Jan 16, 2011 9:39 PM
stein75
10
Mar 25, 2010 11:30 PM
engine2
Jan 6, 2007 6:53 PM
