Tire question
Old Aug 18, 2009 | 1:57 PM
boosted475's Avatar
Default Tire question
Okay at the risk of sounding stupid, I ask this question.
I recently heard that tires actually have an expiration date?
That after X-amount of years even if the tread is good, the rubber is bad?
Can anyone clarify this for me please?
Thanks.
Old Aug 18, 2009 | 2:11 PM
myotherchevyisablazer's Avatar
Thanks.
never a stupid question....iv'e never myself heard of such a theory...my dad did run some tires on his truck for close to 10 years,the were starting to crack a little..who gave you that info was it a tire guy?
Old Aug 18, 2009 | 5:22 PM
demo9pro's Avatar
If your not into burn outs/ and or drive like a granny you should replace your rubber ever 5-7 years. Sometimes even earlier depending on the quality of the tyre.
Rubber dries out and tends to make your ride harsh and also you run the risk of cracking/splitting a tyre at higher speeds which could be fatal.
Dont risk it.
Old Aug 18, 2009 | 6:49 PM
MDTAHOE's Avatar
Professional Mechanic
They do not have a expiration date per say. However tire should only be run 5-7 years depending on the make/quality.After then the risk of a blow out is higher. All tires have a DOT number which contains the date in which they were made.
Old Aug 19, 2009 | 11:21 AM
therewolf's Avatar
OK, LOOK CLOSELY at one of the tires. After a couple years they start to get small surface cracks. Once they appear, there's no rush, but it probably would be a safe bet to say you'd want to be considering new tires in the next 30k miles or two years. Tires literally dry rot when exposed to extremes in weather. (google "ozone checking") Some people say if you turn off the radio, turn out the lights and stay REAL QUIET, you can hear your car's rubber deteriorating. (Not true.)
Most tires are only warrantied up to 4 years against sidewall wear-out.
I personally replace all my tires (spare included) after 5 years, or tread wear-out, whichever comes first.
But this is kind of personal. Some folks go thru tires in two years, some (like myself) 5, while others who drive gently on dirt backroads near home only go thru a set in 8-10 years. I wouldn't wear your wallet out because some salesman is trying to say your tires are worn out. Make up your mind for yourself.
Don't forget to rotate and inflate!
Old Aug 19, 2009 | 11:33 AM
Originally Posted by rivereye
OK, LOOK CLOSELY at one of the tires. After a couple years they start to get small surface cracks. Once they appear, there's no rush, but it probably would be a safe bet to say you'd want to be considering new tires in the next 30k miles nor two years. Tires literally dry rot when exposed to extremes in weather. (google "ozone checking") Some people say if you turn off the radio, turn out the lights and stay REAL QUIET, you can hear your car's rubber deteriorating. (Not true.)
very good point in tire's lasting...im very particular on doing the whole rotate and proper air pressure...it really makes tire's last...espically if it's an investment..great point rivereye
Old Aug 19, 2009 | 8:37 PM
boosted475's Avatar
cool thanks guys
tonymacias
2007 - 2013 (GMT900)
Aug 21, 2012 9:50 PM
lauraherota
Oct 19, 2011 9:04 AM
bamafutbal
Jul 29, 2010 9:24 PM
