Torsion bar ?
Old Feb 26, 2010 | 10:28 PM
nauticstar87's Avatar
Default Torsion bar ?
Cant you crank the front end of a 2wd like you can a 4wd?
Old Feb 26, 2010 | 10:30 PM
gotstylez's Avatar
yep..but i dont think your 07 has torrsion bars
Old Feb 26, 2010 | 10:38 PM
maxxman04's Avatar
yessir. bars are bars. they all adjust the same. but you're rig ain't got em. buy a coil spring spacer to lift front end up. easy bolt on.
Old Feb 26, 2010 | 10:40 PM
Apparently I'm getting schooled on another forum bout this. Cuz i dont know. put up the same pics I have here, they said you need to crank the TBs, I aksed can you do that on a 2wd, apparently im dumb for asking... i do need to do something, im rubbing pretty bad up front.
I'm prolly gonna go the coil spacer route
Old Feb 26, 2010 | 10:44 PM
maxxman04's Avatar
spacer bolts in same way as spring, then spring bolts to it, like normal.
Old Feb 26, 2010 | 11:34 PM
I don't have coils... I just went out and checked. That means I have to have TBs, right?
Old Feb 27, 2010 | 12:55 AM
maxxman04's Avatar
take a look underneath at the front lower a-arm. is there a bar that runs towrds the back of truck, stoppin bout halfway back? if so, you have tb's
Old Feb 27, 2010 | 6:49 AM
mudmaniac's Avatar
Ride of the Month
May 2009
I did a search and evidently you do have torsion bars, here is a link for a leveling kit.
http://www.tirerack.com/suspension/S...+Cab&brand=all
Old Feb 27, 2010 | 3:29 PM
Thanks MudManiac. When i changed my oil yesterday, and not the first time I've changed my oil. i noticed the TBs, but didn't think nothing of it. Then i went and checked later on... Torsion Bars. I feel dumb, I just don't know about Chevy front suspension.
I don't know if i'm just going to crank 'em and get longer shocks, or get the kit.
Old Feb 27, 2010 | 8:15 PM
After soem thought, I decided I'm gonna crank it on thursday. then when I'm back on a normal budget, I'll decrank and get the keys.
