Tranny Selection
Old May 19, 2008 | 10:25 PM
markfothebeast's Avatar
Default Tranny Selection
I don't know what tranny I should go for. I should have around 300hp with my new 350 setup. I bought a TH350c with less than 1k miles and with a shift kit but someone urged me not to use it because "the torque converter clutches would blow up into the tranny and ruin the tranny if I didnt flip the toggle switch at the right time", don't know if thats true. And I dont know how exactly to wire the switch. Anyhow he has a good condition th400 sitting around he would sell me for $300 but I read somewhere that the Th400can rob anywhere from 30-40HP. Is there any proof that the TH400 will rob that much HP?
Old Jun 17, 2008 | 8:46 AM
BurninRubber92's Avatar
Default RE: Tranny Selection
All automatic transmissions rob anywhere from 18-20% of engine horsepower. Manual Transmission rob 13-15%. So, either way you go, you will lose power. That's just the way it goes. If you're running 300 at the crank now, you should expect a 50-60hp loss through the drivetrain.
As for your transmission choice, if it has to be an automatic, i would go with a th400, or a 700r.
Have you considered doing a manual swap?
Old Jun 17, 2008 | 10:07 AM
I swapped in a built-up TH350 last weekend. It was a straight forward swap from the TH200 with no modifications.
returnofsid
Jan 30, 2013 5:41 PM
miltie
Jul 24, 2010 11:33 AM
lift_tech
Jul 5, 2010 11:18 AM
sojo
Dec 21, 2009 4:36 PM
