Transmission noise
Old May 24, 2017 | 1:19 PM
Launce Fields's Avatar
Default Transmission noise
Hi there I'm new to the chevy forums, and was wondering if anyone knew or could possibly help me pinpoint a problem out of my trans. So the noise I'm hearing sounds like gravel in the trans, I believe it's coming out of the bell housing. I only hear it when the wheels are turning, not when it's in idle though. It doesn't matter if it's in drive, reverse, or neutral as long as the wheels move I can hear it. I did find some very small metal shavings on top of the inspection port on the bell housing as well. Any help would be greatly appreciated
Old May 24, 2017 | 2:43 PM
kevinkpk's Avatar
You need to post more information, i.e. type vehicle, standard, or automatic transmission.
Old May 24, 2017 | 3:36 PM
2001 chevy silverado 1500 4 wheel drive 5.3l z71 automatic
Old May 24, 2017 | 4:09 PM
kevinkpk's Avatar
Drain the fluid, and see what it looks like. Could also be a magnet in the bottom of the pan, if so, check for metal
