Transmission or transfer case
Old Jan 23, 2018 | 7:48 PM
brandon26's Avatar
Default Transmission or transfer case
I have a 1984 Chevy k10 suburban, a couple weeks ago while driving the transmission acted as if it was slipping then seemed to be in neutral, if I place the shifter for the four wheel drive into 4high then it will drive a short distance then act as if it's in neutral, then if I put it back in 2high i can continue driving, what would cause it to do that?
Old Jan 31, 2018 | 1:37 AM
alpineskye's Avatar
Default What weight oil would you use for a 76 muncie
What weight oil would go into a 76 muncie tranny? Do you know? Please and thanks
