vacuum test
Old Jun 20, 2012 | 6:54 PM
clintsy's Avatar
Default vacuum test
Sorry if this is such a noob question..
Where do you connect a handheld vacuum gauge to test the vacuum?
on a 85 Impala with the 305 and quadrajet
Old Jun 20, 2012 | 7:13 PM
kevinkpk's Avatar
Valid question. Insert it into the vacuum system anywhere furthest from the carb.
Old Jun 20, 2012 | 8:23 PM
clintsy's Avatar
Thanks..no specific spot or anything?
Old Jun 20, 2012 | 8:35 PM
kevinkpk's Avatar
What exactly are you looking for?
Old Jun 20, 2012 | 8:52 PM
clintsy's Avatar
I'm just trying to test the vacuum to see if I come across any problems and I need to turn the cap until I get the highest reading...since it's my first time ever doing this I didn't know if there was a "best" spot to check for vacuum
Old Jun 21, 2012 | 1:48 PM
SWHouston's Avatar
If you have a Vacuum Canister on your brake system, you probably should do an integrity test first, to make sure there are no leaks. And, a lot of people just use the Tach to get the most RPM's from the setting, then readjust the idle speed.
Old Jun 21, 2012 | 5:43 PM
clintsy's Avatar
well i did the vacuum test, did everything i could to get the highest reading except the idle mixture screws because i need the double d socket or fitting for it..i also took a video of it on my cell phone if anybody wants to see
vacuum test (phone quality) - YouTube
if you cant watch it, the needle measures 19 to 18 in but occasionally flickers to 17...in the video i also look at the tach and you can see it dipping down to about 5-600 then back up to 8-900. which is when i think the vacuum gauge drops an inch to 17
tell me what you think
any input is GREATLY appreciated
thanks
Old Jun 21, 2012 | 6:23 PM
kevinkpk's Avatar
Well, first of all it is a 305. Setting the timming with vacuum is ok, I seem to see around 800 rpm's on the tach, that too is ok. How many miles on the engine?
Old Jun 21, 2012 | 6:32 PM
clintsy's Avatar
55k on the dash but I'm not sure if it rolled
Old Jun 21, 2012 | 6:36 PM
clintsy's Avatar
And it unfortunately does not have the original carb on it.
The owner before me changed it from #17085*** to #17083204
