Very High Idle Issue
Old May 14th, 2007 | 11:27 AM
rat55chevy's Avatar
Default Very High Idle Issue
I have a 97 S10 Blazer with a 4.3L engine that is idling very high. At startup it runs between 2500 & 3000 RPM. Did the general assumption and looked for vacuum leaks. Quite certain there is no vacuum issue. I disconnected the accelerator cable and the engine idles normally. No apparent binding in cable or throttle body. I assume its the PCM doing the accelerating. Is this a symptom of a bad MAP or TPS?
Old May 25th, 2007 | 4:43 AM
luv my truck's Avatar
Default RE: Very High Idle Issue
My guess it's the TPS (throttle positioning sensor) I have a '99 Silverado w/ 5.3 and it did the same thing and I replaced the TPS and it fixed the problem
alka
Astro
March 29th, 2015 9:08 PM
Jing
April 15th, 2011 5:03 PM
jakeywa
December 11th, 2010 8:18 PM
jakeywa
December 11th, 2010 4:29 PM
billyjoe72
October 21st, 2005 5:33 PM
