ABS system
Old May 27, 2007 | 3:31 PM
1995Berretta's Avatar
Default ABS system
Does anyone know anything about the Power Master III ABS system?
I am having trouble with the system in my car. My car is actually a 1991 Olds. Cutlass Convertable. But there is no one on the Olds Forums that know anything about the system.
I know GM used it in alot of the cars with ABS in the early 90's
The brakes kind of went away. Talked to an old GM master tech (That I cant reach now)
Replaced the accumilator which fit what I had wrong at the time.
Then tried to bleed the brake system according to the Factory service manual. The rear bleeder snapped off in the calipers. So I replaced the rear calipers and bled the system.
Drove the car about 10 miles then the brakes started acting up again. When I first press the pedal it is hard then after about 5 seconds it will release and the car will almost lock up the brakes. I need to try to figure this out and get it fixed to be able to drive it on Tuesday.
Please anyone that has any Ideas please post I really appreciate it.
Thanks for any info at all.
Sirius018
Aug 23, 2010 12:24 PM
turboHD
Apr 21, 2010 9:29 AM
Shaun_95
Feb 12, 2010 8:38 PM
esrman
Mar 24, 2009 7:56 AM
mog703
May 21, 2007 8:41 AM
