Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
corsica abs system
Old Feb 4, 2010 | 1:54 PM
turboHD's Avatar
Default corsica abs system
when first applying brakes, the pedal goes to the floor.
after pumping the pedal a time or two it comes up a bit but the passenger side front grabs and pulls car to right
release the brakes and drives normal(no drag) until you need to brake again
seems after the first time, if you just gently pump the pedal, it will stop you and not as much pulling
not very knowlegeable on abs brakes
please help
Old Apr 21, 2010 | 9:29 AM
turboHD's Avatar
ok an update
found out there is no fluid being pushed out of the master cylinder/abs pump to the drivers front/ passenger rear
bought a used one and installed, at first it did push fluid from those ports then it didn't
I'll be the first to admit this has me baffled
could use some insight
thanks
Kerry Doran
Sep 18, 2016 6:23 PM
terry_g
Jun 24, 2010 8:57 AM
esrman
Mar 24, 2009 7:56 AM
1995Berretta
May 27, 2007 3:31 PM
mog703
May 21, 2007 8:41 AM
