vibration/shaking
Old February 24th, 2009 | 6:33 AM
stsscott's Avatar
Default vibration/shaking
Hi All:
I have a 97 s10 blazer 4wd and all of a sudden I am getting a vibration in the front, and it gives off such a noise from it within the cab. I checked all the front suspension parts and they seem ok. It only does it under load, if I coast it stops..................any ideas???
thanks in advance
Scott
Old February 25th, 2009 | 12:31 AM
irdaneel's Avatar
In both 4 and 2wd?
If not, perhaps it is a shake from the motor itself.
Any power problems? Idle changes? etc?
Check your driveshafts as well
Old February 28th, 2009 | 8:03 AM
elbastardo's Avatar
I do not have an s10 but i have what seems to be the same vibration as you described. When i decelerate at low speeds i get a low vibration from the front end, I also have excessive steeringwheel slop. I havent had a chance to look into it yet (just bought the truck). But i need to get it fixed.
Is your vibration somwhat audiable in the cab? asin low humm?
Do you suffer from any steering lag?
And is the vibration the loudest below 20MPH?
Moonlighter625
August 30th, 2015 10:09 AM
greatwhite99
August 27th, 2011 4:00 PM
992door
August 24th, 2009 9:40 AM
MEC407
October 28th, 2008 6:01 PM
Fishheads
March 12th, 2007 8:36 PM
Quick Reply: vibration/shaking
