vibration/shaking
Old Feb 24, 2009 | 6:33 AM
stsscott's Avatar
Default vibration/shaking
Hi All:
I have a 97 s10 blazer 4wd and all of a sudden I am getting a vibration in the front, and it gives off such a noise from it within the cab. I checked all the front suspension parts and they seem ok. It only does it under load, if I coast it stops..................any ideas???
thanks in advance
Scott
Old Feb 25, 2009 | 12:31 AM
irdaneel's Avatar
In both 4 and 2wd?
If not, perhaps it is a shake from the motor itself.
Any power problems? Idle changes? etc?
Check your driveshafts as well
Old Feb 28, 2009 | 8:03 AM
elbastardo's Avatar
I do not have an s10 but i have what seems to be the same vibration as you described. When i decelerate at low speeds i get a low vibration from the front end, I also have excessive steeringwheel slop. I havent had a chance to look into it yet (just bought the truck). But i need to get it fixed.
Is your vibration somwhat audiable in the cab? asin low humm?
Do you suffer from any steering lag?
And is the vibration the loudest below 20MPH?
Moonlighter625
Aug 30, 2015 10:09 AM
greatwhite99
Aug 27, 2011 4:00 PM
992door
Aug 24, 2009 9:40 AM
MEC407
Oct 28, 2008 6:01 PM
Fishheads
Mar 12, 2007 8:36 PM
