Notices
Warm start no go
Old March 23rd, 2015, 10:39 PM
Rideordie763's Avatar
Default Warm start no go
Well I have a 94 k1500 5.7 and it's having a starting issue. It will start perfect when cold I can drive it with no problems but it's having restarting issues. When cold I can start it about 2 to 4 times in a row with no problem but after that it cranks and chugs but won't start, tell I let it sit for a couple of mins. I've replaced fuel relay twice, fuel filter, fuel pump, temp sensor by thermostat, oil switch, plugs, both tbi, rebuilt fuel regulator. No check engine but there is a hard code in the ECu, codes or 32,33,34,54. all those have a bad circuit or ecu problems (the manual says) I also want to stat that my ground straps are green and the one with from the fire wall to the block is green and caked with oil. my next step is replacing the ground straps before replacing the ecm. Help please I'm about 600.00 in the hole with this problem
Old March 23rd, 2015, 10:41 PM
So I'm waiting on a msd pick up coil for distributor 8366 and replacing my ground straps, from to the fire wall and fire wall tho back of the block. If this doesn't fix my starting issue, I'm stuck with my last guess the ecm??
nutsnbolts76
March 30th, 2020 5:41 PM
94burb
March 15th, 2009 11:39 AM
aman721
February 3rd, 2008 4:12 AM
Quick Reply: Warm start no go
