washer pump problem
Old Jan 16, 2010 | 9:33 PM
huey113's Avatar
Default washer pump problem
2008 equinox 3.4
The washer pump dosnt work I checked for power and have power going into the pump so I removed pump and applyed 12volts and nothing, I replaced the pump today and it still dosnt pump I have power and fuses are good what would cause this?
Old Jan 16, 2010 | 9:40 PM
huey113's Avatar
2008 <NOBR style="COLOR: darkgreen; FONT-SIZE: 100%; FONT-WEIGHT: normal" id=itxt_nobr_0_0>equinox</NOBR> 3.4 fwd
The washer pump dosnt work I checked for <NOBR style="COLOR: darkgreen; FONT-SIZE: 100%; FONT-WEIGHT: normal" id=itxt_nobr_1_0>power</NOBR> and have power going into the pump so I removed pump and applyed 12volts and nothing, I replaced the pump today and it still dosnt pump I have power and fuses are good what would cause this? I did see a tsb about the washer pump filter causing low/no flow but would that cause the pump to not pump?
Old Jan 16, 2010 | 11:40 PM
maxxman04's Avatar
have you checked both pumps with straight battery power to make sure they work or not?
Old Jan 17, 2010 | 5:21 AM
mudmaniac's Avatar
Ride of the Month
May 2009
I don't know where you are located, but is it possible that your lines are frozen?
Old Jan 17, 2010 | 9:11 AM
huey113's Avatar
Theres only one pump but looks like in supplies front and rear, yes I applied battery voltage to the old pump and it didnt work.
Old Jan 31, 2010 | 12:16 AM
timmysouthpark's Avatar
Lines plugged? I usually just hot wire an aftermarket pump in. They put out WAY more liquid.
mthoodequinox
May 8, 2014 8:07 PM
CheesePuff
Dec 29, 2009 3:58 PM
diehard911
Jun 29, 2009 6:53 AM
95 Suburban
Jan 13, 2009 10:19 PM
