Notices
What is a "control head"?
Old July 5th, 2012, 10:37 PM
EdH
EdH's Avatar
Default What is a "control head"?
Got a problem with the 'burban. Code reader comes up with B0305....internet search comes up with, "Control head #3 (rear) feedback circuit low" What does this mean???
Old July 6th, 2012, 8:23 AM
Site Ambassador
Camaro 69's Avatar
You sure you're not seeing PO305? The "PO" is a POwertrain code, 305 means cylinder #5 misfire.
Old July 6th, 2012, 7:15 PM
body code hence B....probably refers to the hvac controller head...all the buttons or dials that control the heater/ac functions. Since your internet search defintion says rear; the vehcile probably has rear hvac controls. Does your scan tool name the module the code set in? Hvac control module??
What is the actual problem that your trying to fix?
Old July 7th, 2012, 7:42 AM
looked up that code for a 03 suburban 4wd; its not a valid code.
Are you using an outdated scan tool or entering an older model year with your code reader in order to read the code?
damone
May 8th, 2021 12:36 PM
Keesie
November 15th, 2013 4:46 PM
DOBERDEWD
December 11th, 2011 11:35 PM
chevyman323
July 16th, 2010 11:56 AM
mike688
Uplander
January 25th, 2010 12:16 PM
Quick Reply: What is a "control head"?
