Z71 wont hit.
Old Nov 16, 2010 | 12:06 PM
plowboy78's Avatar
Question Z71 wont hit.
I've got a 98 Z71 with a 350 it ran fine yesterday and now it wont start. Turns over good shows plenty of oil pressure when cranking just doesn't seem to have any spark. I replaced plugs, wires, and distributor cap two months ago. Any ideas on where to start all the ignition dues are good. Thanks for any ideas.
Old Nov 16, 2010 | 12:46 PM
gotstylez's Avatar
i would start with the fuel pump.. turn the key on but dont start..can you hear the pump turn on? then go from there... since thats free..and easy
Old Nov 16, 2010 | 1:48 PM
plowboy78's Avatar
Fuel pump starts with key on runs about 3 to 5 seconds. I also tried a small amount of starting fluid. Didn't even try to hit which leads me to believe its not getting any fire. Is there a ignition relay or anything that could keep it from firing?
Old Nov 18, 2010 | 7:15 PM
frickenbored's Avatar
grab one of these:
http://www.amazon.com/KD-Tools-2757-...0129150&sr=1-8
If you have an HEI system get this one:
http://www.amazon.com/KD-Tools-2756-...129521&sr=8-16
If you can light that thing up then your ignition system is fine. Just unplug an ignition wire and plug it onto this tool, then clip it to a good ground and crank the engine. If this tool sparks your good if not you may have a bad ignition coil or maybe a bad ignition switch.
silveradolt1
10
Feb 17, 2008 1:00 AM
butchermanj
Sonic (Aveo)
Nov 21, 2007 10:50 PM
ironcy
Jan 1, 2007 5:35 PM
