HHR This retro crossover vehicle combines the usefulness of a minivan with the size of a mid sized car.
Platform: Delta
Also Check out ChevyHHR.net
'07 HHR engine temp gauge - engine light
Old Apr 17, 2010 | 2:43 PM
luvmlkwag's Avatar
Default '07 HHR engine temp gauge - engine light
'07 HHR the engine temp gauge only works some of the time - when not working the heater still works but not the A/C. If the engine temp gauge is working the A/C works. The engine light stays on for no apparent reason and the left rear passenger door lock no longer works with the rest of the door locks
Old Apr 18, 2010 | 10:39 PM
s34n's Avatar
pull the code from the check engine light to start with. have you checked a fuse for the power locks?
Old Jun 5, 2010 | 11:05 AM
luvmlkwag's Avatar
It was a damaged thermostat that was causing the engine light to stay on and the engine temp gauge to not work.
The thermostat was all shot to hell, stretched out, torn and missing some pieces. After I replaced it the, temp gauge started working again and the engine light went out after I had driven about 24 miles and has not come on since.
Roslyn2005
Feb 23, 2017 9:03 AM
Thomas1988
May 21, 2014 9:36 AM
montana suburban
May 11, 2010 5:19 PM
Mauler
Mar 2, 2009 6:40 PM
wrxsubaruwrx
Dec 3, 2006 12:33 PM
