HHR This retro crossover vehicle combines the usefulness of a minivan with the size of a mid sized car.
Platform: Delta
Also Check out ChevyHHR.net
2007 HHR 2.2 Tensioner Pulley Replacement
Old Dec 11, 2011 | 10:32 PM
shawnboymichigan's Avatar
Post 2007 HHR 2.2 Tensioner Pulley Replacement
Would anyone know how to replace the Pulley?
Thanks
Shawn
Old Apr 5, 2022 | 9:10 AM
HHR guru's Avatar
Thanks
Shawn
there's an opening near your passenger strut to remove one bolt. You need to remove the belt as well. You need a tensioner wrench, which is basically a flat bar, with a3/8 socket pin. Bout 25$
Old Apr 5, 2022 | 9:12 AM
HHR guru's Avatar
Thanks
Shawn
Old May 27, 2022 | 3:23 AM
HHR guru's Avatar
Thanks
Shawn
there is a bolt to hold the tensioner in place .remove belt. There is a small access point under the passenger fender.its probably covered by plastic. Remove it and you can reach the bolt... also make sure you don't drop that bolt into the chassis.its tricky. Use a piece of string to keep that bolt from falling in or you'll have hell replacing it. You need a serpentine tool also to reinstall the belt
Tekmon
Mar 19, 2018 8:26 AM
tom p
Nov 19, 2014 10:26 AM
j5403h
Jun 24, 2011 10:23 AM
davethewav9
Jun 4, 2011 11:29 AM
Grem
Nov 12, 2007 12:22 PM
