HHR This retro crossover vehicle combines the usefulness of a minivan with the size of a mid sized car.
Platform: Delta
Also Check out ChevyHHR.net
2007 HHR Won't Crank/Start & No Fuel Pump
Old Apr 20, 2018 | 9:57 PM
Bpopilek's Avatar
Default 2007 HHR Won't Crank/Start & No Fuel Pump
Hello all. I'm currently working on a 2007 HHR that belongs to my sister. I'm at my wits end and could really use some help. This particular HHR is mostly a base model with the 2.2l ecotech engine and a manual transmission. Turning the key does nothing. The car will not try to crank at all, and the fuel pump doesn't turn on.
So far, here is where I am at with my testing:
  1. I first verified that all of the fuses and relays in the vehicle were good. I next made sure that the battery was fully charged and I have kept a high end trickle charger connected up while working on it. Lastly I checked to make sure that there were no check engine codes by scanning the computer.
  2. I did find some remnants of a remote starter that the original owner had on it. Many wires from an aftermarket unit were connected up under the dash. It was wired up to the PK3 key sensor, ignition power wires, brake pedal switch, and over to the bcm as well. I removed everything that I could find.
  3. The fuel pump does not try to prime when I turn the key to the on position. If I jumper the relay under the hood, in the fuse box, the pump turns right on.
  4. I decided to pull the starter and test it outside of the vehicle. I found that the solenoid was dead. However, the starter had been slowly dying prior to the current situation. A bad solenoid couldn't have damaged something else in the starting system could it?
  5. Next I tried connecting my multimeter to the starter wires, and with the starter still out I had my sister turn the key. Unfortunately, it couldn't be that simple and I saw no voltage on the starter wires.
  6. There are no security lights when using the key. To make sure it wasn't a computer problem, I tried swapping in a used ECM from another 2007 HHR with matching numbers from a local junk yard. I dId realize that this wouldn't fully work since the VIN numbers do not match, but I have an HP Tuner and can reprogram a replacement if necessary. The only thing that I saw different with the new ECM installed was that the security lights came on in the dash. The car still didn't try to crank over, nor did the fuel pump try to prime. A quick check of trouble codes now showed a crank position sensor error that I couldn't clear. I decided to put the original computer back in the car.
  7. I next tried a couple of different ignition switches that I got at the junk yard, and yet again I still got the same results of no starting.
  8. Lastly I did some further testing in the fuse box under the hood, I found that the I/P IGN fuse never gets any power, and the crank relay never gets power or engages.
Because my sister is on limited income, she can't afford to take it in to the dealership to get it fixed. And without it she can't get to work on her own. Therefore, it is up to me to get it fixed and at this point I am fresh out of ideas! I have no clue as to why I can't get power to the fuel pump or to the starter. I've read through multiple websites/forums and I've spent many hours searching online, but I haven't found the solution that I need. I'm hoping that someone here may have some idea of additional tests that I can perform. Any help at all is greatly appreciated. Thank you for reading!
