HHR This retro crossover vehicle combines the usefulness of a minivan with the size of a mid sized car.
Platform: Delta
Also Check out ChevyHHR.net
2011 hhr speaker issue
Old May 28, 2017 | 9:11 AM
peteman44's Avatar
Default 2011 hhr speaker issue
the right side speakers are real low volume until the vehicle is 83 degrees then they work ok. Is there a way to access the rear of the radio without taking the center console apart as per the radio removal instructions. I just need to get my hand on the connector.
Thank you
peteman44@hotmail.com
Old May 28, 2017 | 10:01 AM
I wonder if you can remove the center console face plate then move the shifter to neutral. if this allows you to remove the radio face plate and heater controls the radio should come out.
