Adding back the OnStar/Bluetooth
Hello all, first post cherry pop, just purchased a 2009 Chevy HHR LT/LT2 vehicle. This was a slightly used beauty from a rental car place in Florida.
The problem is that I think because it was a car rental place, they removed the OnStar system as well as my bluetooth system (I have read that the two go hand in hand?)
I know that the vehicle at one point had to have had both the items. At the front of the car roof is a spot for a small antenna. There is a small cutaway in the headliner where the cable for the special rear-view OnStar mirror must have gone (I am assuming that the buttons were part of the rear-view mirror). The steering wheel is a leather-wrapped job with the Bluetooth buttons. When I press and hold the "mute" button for more than two seconds as the book states, the bluetooth does not activate.
I am guessing they gutted the OnStar system due to rental. I haven't yet taken the time to take the rear panel out to see if they removed the module or not.
Bottom line: I want to use the bluetooth with my vehicle's factory radio system. If I need to reinstall the OnStar, then so be it... in fact, I wouldn't mind having the OnStar for certain things anyway. My biggest question is what will I need to get everything back up an operational? Here's what I think is the short list so far:
-OnStar Module (installed in rear-right)
-OnStar equipped rear-view mirror (w/buttons)
-"stubby" antenna (there is none in the front roof antenna currently)
Anything else? Also, do you know if the OnStar will give me bluetooth, or is there something else I need? (I'd rather not do anything 3rd party-wise if possible.)
I didn't look as hard because I actually called Chevy/GM Customer Service and gave them the VIN. The person that took my call stated that there was never an OnStar/Bluetooth system registered for my vehicle.
So, I guess my question to any of you GM people out there is if I can purchase an OnStar/Bluetooth "kit" and install it, or should I just bite the bullet and get an aftermarket Bluetooth setup (parrot) with a LockPick harness so I can pump it through the radio?
Well, having OnStar and factory Bluetooth would be nice... is anyone aware of a package that will let me install both back into my HHR, or would I have to suffice for a "parts" vehicle to hope to get them?
Well, after calling my local Chevy dealer's service dept. and speaking at length about this, here's what I found out:
1) My vehicle never had OnStar, Bluetooth or XM installed OEM (even though my steering wheel has the B/T buttons and the radio has the XM "Category" button).
2) There is no GM Parts/package that can be ordered to install in a vehicle that never had OnStar or XM to my dealer's knowledge.
3) My only hope for going OEM on anything would be to find a "Parts" vehicle for the same year that I could grab all of the wires, etc. for and install it myself. Even then, it would necessarily work as it may require special wiring, stereo, etc.
So, it appears that I will have to go aftermarket for the Bluetooth feature, and I will not be able to have OnStar in this vehicle, unless I can find a totaled 2009 HHR with those systems still intact. Maybe at some point I will just bite the bullet and purchase an aftermarket Stereo/DVD that has built-in bluetooth and will utilize the steering wheel controls. Now I just have to try and get approval from my wife, lol
latropa
Apr 17, 2014 9:27 PM
Boris
Nov 4, 2012 9:54 AM
mjs31
Mar 25, 2010 10:23 AM
