HHR This retro crossover vehicle combines the usefulness of a minivan with the size of a mid sized car.
Platform: Delta
Also Check out ChevyHHR.net
HHR knock sensor
Old Oct 26, 2009 | 2:48 PM
Larryrb's Avatar
Default HHR knock sensor
You guys are an incredible wealth of information and I've learned so much by just reading. Now I have what may sound like a silly question, but I'll ask anyway. We're getting a code for a bad knock sensor and I want to replace it. Where on the engine should I look for this thing? My intention was to get the new one and then look for something that looked like the new one, but somehow I guess it would be simpler to know where to look in the first place.
Thanks guys.
Old Oct 26, 2009 | 4:21 PM
shawnvw's Avatar
Banned
Old Oct 29, 2009 | 6:41 PM
Larryrb's Avatar
Thank you very much for the great drawing. I really appreciate it.
Old Oct 31, 2009 | 1:35 PM
longtimechevyfan's Avatar
Larry if you are going to buy a new one I would suggest for getting your chevy parts for your hhr to buy them from http://www.chevyclub.org/chevy-hhr-parts.html they will be quite a bit cheaper than your dealer. This sensor should not be hard to replace.
Edited because apparantly I cannot spell!
Old Nov 1, 2009 | 2:20 PM
Larryrb's Avatar
Thanks, longtimechevyfan. I may do just that. And certainly will save the web address for future use.
Thanks again.
Old Nov 7, 2009 | 10:12 AM
Larryrb's Avatar
Time to share the wealth. Finally got around to replacing the knock sensor. This is my wife's car and between her work, grocery getting and Walmart it was hard to find time for this. Shawn, thanks for the great drawing. It headed me in the right direction. The only way to approach this is from under the car. The knock sensor can be found right above the starter. Just a matter of unplugging the old one and removing the bolt that secures the sensor to the block. Although it appears to be nearly impossible without removing the starter, it's actually fairly simple to do so with the starter in place. The connector is out in the open. So that part's easy. A short 3/8 drive 13 MM socket, a short extension and a 3/8 ratchet (with a swivel head) allows you to remove and replace the sensor. I suppose knowing what I know now I could do this in half an hour. This does not include the half hour it took to retrieve a dropped socket from a cavity behind the starter.
Thanks again for the help. I appreciate it.
Old Nov 7, 2009 | 7:29 PM
nauticstar87's Avatar
Thanks for coming back and letting us know how you fixed it. Wish everybody would do that.
Old Nov 8, 2009 | 1:46 AM
Glad you got it fixed.
Old Jan 12, 2010 | 2:59 AM
mikeross's Avatar
Encountered the same problem.. bad knock sensor. but until now it is not fixed yet. Had no time during the holidays but now I am working on it. Thanks for the illustration. Great help.
Old Apr 28, 2015 | 5:02 PM
Rachel s's Avatar
Originally Posted by shawnvw
I wish I could see this pic
jdog
Dec 10, 2024 12:11 AM
platvinc
HHR
Apr 8, 2015 6:55 PM
jffgin
Mar 10, 2008 2:32 PM
jamesdal7
Jul 18, 2006 11:11 PM
