HHR This retro crossover vehicle combines the usefulness of a minivan with the size of a mid sized car.
Platform: Delta
Also Check out ChevyHHR.net
Horn blows while driving.
Old Oct 24, 2018 | 12:29 PM
Barb O.'s Avatar
Default Horn blows while driving.
Horn will blow while turning or in reverse. Not an alarm, but a solid blast. A couple times, it went for about about a minute, then stopped on it's own. Pulled the fuse and relay for now. Could one be going bad?
Old Oct 24, 2018 | 2:36 PM
If one of them is going bad it would be the relay which you can test by changing it with another relay with the same number. More than likely it is a problem with the horn button in the steering wheel or a partially shorted wire in the steering column or where it just comes out of the steering column.
Old Oct 24, 2018 | 4:26 PM
Barb O.'s Avatar
It's sounding like the clock spring in the steering wheel. Thanks for your feedback. Am going to keep the fuses pulled until it's fixed. Waking up my neighbors at 6am isn't fun.
