2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
01 impala hard shifting problem
Old Oct 20, 2013 | 9:48 AM
  #11
fcabezas's Avatar
Originally Posted by joezzee88
this is a big problem with GM cars trannsmissions. you need to install a shift kit. it will fix your problem. mine did that. it would be fine until i get into stop and go city traffic. the computer see's that the your transmission is slightly slow on it's shifts and will gradually increase transmission pressure until it eventually maxes out the pressure. you can turn off the engine and it will reset the comuter but it will do it again after so many shifts. you can fix it by installing a shift kit to speed up shift time. all you do is shim up the pistons and springs in your transmission accumulator. and it will speed up shift time so the computer wont recognize the the slow shift and max out transmission fluid pressure. you can access the accumulator by dropping the transmission pan underneath your car.
Please can give more indication how to get the accumulator, Is it an easy job to do? Do I need special tools? I understand I can shim it with some aluminium washer I can made, which size is it and how much I must shim it? I have got the pan out to change filter an oil before and it is not hard work.
Thanks in advance for your reply
daanders
Jun 30, 2015 11:40 PM
peerware
May 1, 2013 6:46 AM
First Chevy Truck
Feb 10, 2011 12:21 PM
marky68
Apr 26, 2007 10:11 PM
Summett
Feb 13, 2007 2:59 PM
