02 impala base aftermarket stereo
hi long time lurker first time poster. help would be appreciated. i am trying to put a double din in my 02 impala base 3.4 non onstar non bose. we bought the harness for 19.99 from radio shack and it plugs right in just a typical one no door chimes or anything. got it wired up and the deck turned on but no sound. the car does have a factory amp in the trunk. i do not want to relocate the stock HU what do i need to make t his work. i believe Walmart has the schoch door chime interface thing GMRC-01. is this what i need to make it work.
ive waited two weeks and im getting impatient i just want to put my car back together
thanks,
cole
thanks,
cole
What are the rpo options codes for your car? Look under the trunk spare tire cover for a grey sticker. post the ones that start with U.
The speaker configurations are different depending on the options. The new head unit may be seeing different ohms values between the front and rear speakers. It will think this is a short and stop all output. If the new unit works with one group of speakers disconnected (either all fronts or all back) that is the problem.
I went to Walmart bought the schoche door chime interface wired it up like normal ran a 12v constant lead and bam works perfect. Way easier than any other way I've read and the interface was only 40 bucks. Now to figure out the mounting kit
The interface said 2000-2005 gm vehicles without Bose premium and onstar but it would work with onstar you just wouldn't be able to use onstar. The back of the kit said 03-05 impala a but worked just fine for my 02. I hope this was helpful
shadyjewmobster
April 23rd, 2010 2:58 PM
Colt Hero
April 30th, 2008 4:03 PM
