2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
03 impala a/c
Old Jun 19, 2008 | 9:20 PM
hindesketchup's Avatar
Default 03 impala a/c
i have an 03 impala. the driver's side a/c vents put out warmer air by 15 degrees, while the passenger side works as normal at 55 degrees. recognized the problem as 'hvac side to side temp. difference'? would the problem be fixed by the climate control circuitboard or under the hood?
Old Jun 21, 2008 | 9:19 AM
shawnvw's Avatar
Banned
Default RE: 03 impala a/c
Could be the climate control unit, or a bad actuator that controls the temp on the drivers side
Old Jun 23, 2008 | 6:39 PM
HotSauce6226's Avatar
Impala Super Moderator
X2
Old Jun 24, 2008 | 4:27 PM
what does "X2" mean?
Old Jun 24, 2008 | 4:39 PM
means i agree with what he said
Old Jun 24, 2008 | 4:52 PM
could you be more specific about what the bad actuator and the climate control unit are?
Old Jun 25, 2008 | 10:24 AM
the whole unit that has the heating and air on it
Old Jun 25, 2008 | 8:11 PM
shawnvw's Avatar
Banned
The are 2 temp blend doors on the heater box, and actuators(or motors) that open and close them depending on what the HVAC control unit tells it to do. If the HVAC contorl unit is telling it false info, it won't work properly. Also won't work properly if the motor itself is bad
Old Jun 14, 2009 | 10:11 PM
amym1586's Avatar
did you figure out your problem?
my 01 Impala is doing the exact same thing.
Old Jun 15, 2009 | 5:42 AM
Suggestions are above
