2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
08 Impala speedometer acts up and makes car stall when wet
Old Jun 13, 2016 | 9:30 AM
Gabe Conti's Avatar
Default 08 Impala speedometer acts up and makes car stall when wet
i have a 08 impala ls that the speedometer acts up when its wet outside, it goes up and down untill i see a 107 mpg message then car cuts off, all that happens while stopped on D, i have swapped the speed sensor on the tranny but i still have that issue
any ideas why?
Old Jun 13, 2016 | 12:27 PM
Frank3's Avatar
I would get it scanned for any codes that maybe available.
Old Jun 13, 2016 | 1:06 PM
Gabe Conti's Avatar
i did scan have it scanned but nothing comes up, this thing got me scratching my head
Old Jun 14, 2016 | 11:32 AM
Frank3's Avatar
WOW, I'm scratching my head too! Does your scanner have the ability to display live data? You could watch the speed on the scanner and see if it goes up and down like on the instrument panel. Maybe try to narrow things down a bit and see if the jumping speed is due to bad incoming data to the cluster.
Old Jun 14, 2016 | 3:22 PM
blue-impala's Avatar
Could be a bad ground, Look for and clean all ground connections, battery and any ground straps.
Old Jun 15, 2016 | 9:13 AM
Gabe Conti's Avatar
I will check that next, its possible but that still doesn't explain why it only happens when wet
thanks
Old Jun 15, 2016 | 9:14 AM
Gabe Conti's Avatar
yes live data shows the same thing
