2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
1963 impala
Old Sep 22, 2014 | 4:41 AM
rustbucket2's Avatar
Question 1963 impala
Hello everyone, I am new to this site I have a question about my impala.
I installed a new distributor in my motor electronic bought t from a swap meet . I installed it works fine. starting without the key installed the new igniton can start it with the key but it will not shut off any ideas plz
Old Sep 22, 2014 | 6:05 AM
Something is obviously wired wrong. You must have wired the 12 volts from a source that is hot all the time instead of a source that is only hot when the key is turned on. A schematic of how you wired it would be of great help to find a solution.
Old Sep 22, 2014 | 6:11 PM
it may sound funny when I use a light switch on the positive lead of the coil I can shut it down, basically a kill switch. Basically what I need to do is find the on wire of the ignition and run to battery with a fuseable link in it or from the fuse panel.
Old Sep 23, 2014 | 11:37 AM
Do it correctly. Find a 12 volt source that is only hot when the key is on and use that. Don't put in kill switches or tap off the fuse panel.
Old Sep 24, 2014 | 7:23 PM
ok I will do that I wish you were closer to help me
Old Oct 18, 2014 | 9:58 AM
Default ignition problem
I have a problem stiil with my 63 impala start with the key cannot shut off with it but if I turn on the wipers then turn off the key it shuts off I am baffled the wires on the outside the fuse panel seem to be in the right place according to the book I have
aphelps
May 8, 2008 12:07 PM
shaft24
Mar 19, 2008 4:12 PM
tinascars
Feb 21, 2008 6:08 PM
shaft24
Nov 27, 2007 1:15 PM
