1963 Impala SS 4spd Stuck in 1st gear!!!
Alright here is the deal. I was installing a new carpet kit and front console in my 63 Impala SS. I am not a newbie nor retarded. However, I was wrapping up the install i went to shift and I noticed it would NOT move out of gear! WTF!! I took off the front console and exposed the shifter. I did not notice anything out of sort. I jacked up the car and looked under neath to see if anything had fallen and jammed the linkage. Nothing i can see. Now I am NOT a transmission guy.. I have never owned a 4 speed car before. Here are a few observations:
1. while taking the shifter lever out i lost one of the two bolts that held the after market hurst ****er in place. I still can't find it. (it doesn't mean it is hung up somewhere neither)
2. The clutch engages as it should and I can ddrive it into the garage just fine in 1st gear.
3. I engage the clutch and the shift if fricken frozen in first like a SOB. It will not even hint of moving into neutral or anyother gear.
4. I can take pics, cause i dont even know what kind of trans i have.
y'all got any ideas, short of dropping the transmission?
Is it a T10? Your going to have I think 3, but I know 2 shifter rods that hook to the transmission. I don't know the history, or about the missing bolt but, I'd suggest drop the shifter rods, and with a screw driver pop the fron shifter back to see if it will get out of gear.
gulfstream
January 7th, 2008 4:36 PM
rcbigblock
March 21st, 2006 12:16 PM
rcbigblock
March 16th, 2006 8:52 AM
