2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
1966 Impala Sport Sedan
Old Apr 8, 2011 | 4:24 PM
Trickyspark's Avatar
Default 1966 Impala Sport Sedan
Hello,
Proud owner of a 1966 Sport Sedan that I just purchased, shadetree mechanic, and no where near a the body repairman I wish I was.
I'm having a horrible time finding sheetmetal for my 4-Door, 2-Door metal is all over the place and I was hoping someone might help me out.
I've checked EVERY supplier of aftermarket sheet metal I can find online, and none have the two parts I need. I was looking for a preformed panel that has the rear windshield window channel as I noticed rust around the trim, and I fear horror once I remove as there are pinholes I can see light through . I was also looking for a passenger side toe board (goes between floor pan and firewall).
I can't find either, and I'm scared to try and fabricate something (although the toe board seems to be just a flat piece of metal at an incline). The window channel scares me. I was hoping for specific help or advice from anyone that's repaired or had something like that fixed. I really don't want bondo/fiberglass in that area from all the horror stories I hear come later down the road.
If anyone had their's fixed, was it horribly expensive, $1000's of dollars? Did you find a preformed piece? Could you give me any advice?
Old Sep 16, 2011 | 11:20 PM
roofus1966's Avatar
Default Parts
You can use the rear glass channel from a two door sedan or caprice. The whole roof will not work but the chnnels will. The front windshield channel will also work. Also I do not promote stuffing and puddying however, for a guy who is not a great metal worker you might try to use some fiberglass cloth and resin, this technique works well and is water proof.= and is certainly more acceptable than newspaper and body putty.
Just make sure you use a rust neutralizer and clean clean clean the work area.
ccnchevroletforum
Sep 24, 2012 9:19 AM
cartitles
Oct 21, 2009 3:15 PM
redneckromeo407
Jun 30, 2006 7:15 PM
