2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
1984 Impala Compressor leaking
Old Sep 20, 2010 | 3:32 AM
Rastas's Avatar
Default 1984 Impala Compressor leaking
Is it pretty easy to change comp.....it is leaking at front seal.Do you need to replace accumulator also? Need to convert to R134?
Old Sep 26, 2010 | 11:10 AM
klutz1's Avatar
Most likely you will need to replace the accumulator/drier if the system is opened. There may be shut off valves to isolate the accumulator. If there is you are in luck. Don't know if that seal can be replaced in car but that is the way to go, if possible. The important part, after removing a comp. is the evacuating and recharging the system. Do you have a vacuum pump to do that? Moisture and air are the killers of A/C systems. If you can't do it get an expert that ONLY does AC systems. If the AC was working well before you may be better off changing the seal in that rather than buy OPJ.
joeincharlotte
Mar 28, 2014 6:48 AM
Roberto707
Mar 22, 2012 4:35 AM
oehq.com
Apr 6, 2010 3:40 PM
jorgie5150
Jan 27, 2007 5:18 PM
