2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2000 Impala with fuel gauge problem
Old May 24, 2014 | 12:53 AM
bar422's Avatar
Default 2000 Impala with fuel gauge problem
I have a 2000 Impala with the 3.4 in it and the fuel gauge is not reading correctly. It was at between 1/4 and 1/2 the other day and I went to put fuel in and could only get about 7.00 in it (I clicked the pump a few times and wound up getting 11.00). I know it should have held more....I am being told the fuel sensor on the fuel pump is bad. The car is running fine and I figured if you have to drop the tank to do the sensor you might as well do the pump too. My question is should I check anything else before spending the big bucks for the sensor and the pump and how big of job is this. I would appreciate any info on this.--Thanks!
Old May 24, 2014 | 5:35 AM
blue-impala's Avatar
You do not have to drop the tank, there is a access plate in the trunk floor to get at the fuel pump from the top side of the tank. The pump and fuel gauge sensor unit are one unit. I had the same problem when I had my 2001 Impala. I got a used one from a junk yard and it worked fine for the rest of the cars life.
Old May 24, 2014 | 9:30 AM
bar422's Avatar
I didn't know about the access plate.....I have heard of people cutting one to avoid dropping the tank. I will pull the carpet back and check it out. This would make it a lot easier. Is it screwed close or how does the panel close?
Old May 24, 2014 | 11:07 AM
It is a metal plate, kind of oval in shape and held down with about a half a dozen screws. Its near the back of the trunk.
Attached Thumbnails 2000 Impala with fuel gauge problem-fuel_pump_access_cover1.jpg   2000 Impala with fuel gauge problem-fuel_pump_access_cover2.jpg   2000 Impala with fuel gauge problem-fuel_pump_access_cover3.jpg
hspears
Oct 10, 2012 10:08 PM
wrxsubaruwrx
Dec 3, 2006 12:33 PM
catboater
Astro
Jul 25, 2006 2:56 AM
catboater
Jun 26, 2006 9:07 PM
