2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2000 Impala p0452 code
Old Sep 27, 2019 | 7:04 PM
Bryanward1891's Avatar
Default 2000 Impala p0452 code
I can't find any threads. I have a 2000 Impala with 135000 on it. I've got a p0452 code, does anyone have a pic or schematic as to where the evap code sensor is? Thanks for the help.
Old Sep 27, 2019 | 9:03 PM
there is no evap code sensor.
the code that set is for a low voltage at the fuel tank pressure sensor.
the fault could be wiring or a bad ft p sensor
the sensor location may be on the fuel pump module. your car should have an access door on the trunk floor. remove the door unplug the sensor and see if the high code dtc sets. if it does, replace the sensor. if the low code still sets the fault is probably in the wiring.
Old Sep 27, 2019 | 9:37 PM
Thanks, I'll try that tomorrow.
Bryanward1891
Sep 25, 2019 5:19 PM
L36_IMPALA
Feb 3, 2013 11:02 PM
bobbobgb1
Jun 23, 2012 9:21 PM
newcster68
Nov 13, 2007 12:00 PM
