2000 impala revving and shifting poorly in the rain
I have a 2000 impala 3800 engine...... Last week while it was raining I started having the following symptoms:
-very high idle. stayed at 30% or so steady throttle. The engine was racing.
-rough or failed starts cold starts unless gas was applied. After a few seconds the engine would start racing again.
-high RPM shifting.
Did some research and consulted with a mechanic friend and he suggested the TPS sensor. Replaced this $30 and 10 mins but sadly no immediate change. Same condition continued until about 2 days later (dry weather) and then it started running and shifting better than it ever had the whole time i have owned the vehicle.
It rained again today and the condition returned.
-revving but not as high
-cold start problem is gone.
-late or high rpm shifting. To get a shift to happen I have to run up the RPMs and then feather the gas back off and then the shift will happen. Same for all gears.
Any thoughts? I am broke and need to try and fix myself but don't want to throw anymore parts guessing at the problem.
-high RPM shifting.
Houston36
20
March 3rd, 2008 8:22 PM
