2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2008 Impala LT Stuck In Park
Old May 15, 2010 | 8:51 PM
mjpmin's Avatar
Default 2008 Impala LT Stuck In Park
I rotated my tires on my 2008 Impala LT today by jacking up the car with a floor jack and using a jack stand. I had the emergency brake on. After I was done with the job, I started my car and I can't get it out of park. My shifter is in the middle counsel between the two front seats. Any ideas why this occuring and how I can fix it?
Thanks,
Mike
Old May 15, 2010 | 9:46 PM
gotstylez's Avatar
u might get somebody to rock the car back and forth and try to put it in gear. it could just be in a jam..worth a try lol
Old May 15, 2010 | 9:57 PM
mjpmin's Avatar
Before I posted, I tried rocking it back and forth several times and no luck.
I found the interlock over ride so I can manually get the shifter out of the locked position. The shifter still won't move out of park if I don't use the manual over ride. At least I can drive it to the shop.
Mike
Old May 16, 2010 | 6:08 PM
dman001948's Avatar
Can you get at it from underneath and maybe tap the linkage with a hammer. Not smack hit, but just hit and see if that frees it up. On older cars it use to work.
Old May 18, 2010 | 12:53 PM
Official GM Rep
I would suggest taking the vehicle to a dealership. Your vehicle has a 5 year 100,000 mile powertrain warranty which under normal circustances should cover this kind of work. I hope you are able to get this issue fixed.
Jeff Morris, Chevrolet Customer Service
BigblackHo3
Apr 5, 2013 8:54 AM
fredski53
Jul 21, 2008 11:45 AM
bdawg0958
Sonic (Aveo)
Nov 18, 2007 2:07 PM
txsugarbear
Nov 17, 2007 7:55 AM
bdawg0958
Nov 5, 2007 3:55 PM
