Sonic (Aveo) The subcompact known globally as the Aveo since 2002 is now the SONIC in North America as of the 2012 model
Chevrolet Sonic
GM Platform: T200, T250, T300
Stuck in park
Old Oct 30, 2007 | 12:12 PM
bdawg0958's Avatar
Default Stuck in park
My 2002 Aveo is stuck in park. To move gear selector you have to stick the key in this slot by the shift selector, then it will move. Can anyone help with this problem? Thanks
Old Nov 1, 2007 | 6:27 PM
p.hinds's Avatar
Default RE: Stuck in park
do the brake lights work?if not replace the stop lamp switch.if yes replace the floor shift assy
Old Nov 18, 2007 | 2:07 PM
fujin17's Avatar
When I had this problem with my Aveo, it turned out to be the fuse for the radio. I had intalled a sub and was blasting the radio at the store. The fuse for the radio blew and I just figured I'd get home and replace it. The car would not move out of park unless I used the release. After I changed the fuse, it worked again. Check to make sure that all of the fuses are intact in your car.
BigblackHo3
Apr 5, 2013 8:54 AM
bdm408
Sep 7, 2008 6:24 PM
fredski53
Jul 21, 2008 11:45 AM
txsugarbear
Nov 17, 2007 7:55 AM
bdawg0958
Nov 5, 2007 3:55 PM
