2001 Impala - AC and Heater not working
I have a 2001 Impala. A while ago my AC/Heather Controls 1-4 would work and not 5. About 3 months ago controls settings 1-4 did not work and only 5. Every so often 5 would cut in and out. Just 3 days ago setting 5 stopped working all together (Now none of the settings work). This happened once before then setting 5 started back up again. When it works, it works really good. I have done my research online and I believe it's the Motor Blower Resistor, does this sound right? I can buy it at AutoZone and install it myself. Although, I would like some opinions before I try this. Thanks!
Could be the blower motor resistor, but when they fail they tend to only give the highest and/or only the lowest speeds nothing in the middle. You could have a bad blower motor. And it cant ramp up or tone down in response to the switch because its bad. Anyway, they are both in the same place. Usually 3 tiny screws to a cover and the things flops right out. The resistor is in close proximity to it with 2 tiny screws holding it in also.
MrEarp
August 23rd, 2012 1:40 PM
bxchk
March 1st, 2012 4:12 PM
