2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2001 Impala No power to ECU
Old Dec 21, 2014 | 8:17 PM
JayyKidd's Avatar
Default 2001 Impala No power to ECU
Recently changed motor, Now my problem is the ecu is not getting power and the brake lights stay on as if i have my foot on the brake. I have all power to radio and dash but no ECU or fuel pump. I have double checked all my wiring and grounds, changed bcm, ecu and ignition switch. Its a Ls 3.8. Any suggestions or help???
Old Jan 22, 2015 | 10:30 PM
Jaybird1189's Avatar
Have you checked your relays? Maybe you blew something when you hooked everything back up?
Did you double check your wiring with a multi-meter or just visually?
Relays and Fuses would be the first place I would look.
Old Jan 22, 2015 | 11:03 PM
sledge.impy's Avatar
Reminds me of when I replaced a transmission and upgraded some suspension parts.
I blew my horn fuse at some point... never expected that - and only found out after I failed state safety inspection.
Old Jan 23, 2015 | 8:03 AM
Frank3's Avatar
If you didn't do any work under the dash the disturb the brake switch, maybe a ground was left off when the engine swap was performed and power is somehow backflowing through the brake lights. Check to see if all grounds were reconnected.
patsusedparts
Jun 5, 2010 5:56 PM
dirt_track_racer
Sep 19, 2007 9:10 PM
itsthajbear
Sep 13, 2007 9:21 PM
rn2686
May 23, 2007 12:03 AM
abew330
Apr 14, 2007 8:53 PM
